Zum Hauptinhalt wechseln
Apex TM772 Rear Camera Replacement
Was du brauchst
  1. Apex TM772 Rear Camera Replacement, Rear Camera: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • The rear facing camera is located at the top right just below the front facing camera as looking inside the device.
    • With tweezers or your fingers remove the tape covering the camera’s pin connector.
  2. Apex TM772 Rear Camera Replacement: Schritt 2, Bild 1 von 1
    • With tweezers, flip the black latch to open the pin connector and remove the cable.
    • The camera is adhered to the device with double sided foam tape. Carefully remove the camera from the tape with a metal spudger. If the tape is damaged, you’ll need to replace it.
    • Replace the camera with the new one and assemble the device in reverse of these instructions.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 9
Insgesamt: 77
