Einleitung
Replace a faulty antenna on the AirPort Extreme Model A1034.
Was du brauchst
Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
Unplug the black connector on the top of the metal casing by gently pulling horizontally.
The circuit board connected to the antenna is attached to the metal case with foam adhesive.
Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
