Zum Hauptinhalt wechseln
  1. Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing. Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Unplug the black connector on the top of the metal casing by gently pulling horizontally.
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Remove the four 4.3mm phillips screws from the bottom of the metal casing.
    • Remove the four 4.3mm phillips screws from the bottom of the metal casing.
  6. Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • Lift and separate the top and bottom of the metal casing. You will now expose the motherboard and the AirPort card.
    • To remove the AirPort card, gently pull the plastic tab horizontally.
  7. Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Locate and remove the three 5.0mm phillips screws from the heat sink.
    • Lift to remove the heat sink from the motherboard.
  8. Locate and remove the five 7.5mm phillips screws from the motherboard. Lift and separate the motherboard from the bottom metal casing.
    • Locate and remove the five 7.5mm phillips screws from the motherboard.
    • Lift and separate the motherboard from the bottom metal casing.
    • There will be a loose hexagonal female screw extender under the motherboard.
  9. Desolder the six connections located under the USB. Refer to Wie man Lötverbindungen herstellt und entlötet for soldering techniques.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Michael Garcia
387 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 17-15, Regan Fall 2011 Mitglied von Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 2,949
