Zum Hauptinhalt wechseln
Apple AirPort Extreme Model A1354 Back Pad Replacement
Was du brauchst
  1. Apple AirPort Extreme Model A1354 Back Pad Replacement, Back Pad: Schritt 1, Bild 1 von 1
    • Caution: the back pad is secured with glue so remove it gently to avoid ripping the pad. You may have to repeatedly pull and release to loosen up the glue.
    • First start by peeling off the outer rubbery covering on the bottom of the device. This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
    • Continue peeling back on the pad until it is removed.
  2. Apple AirPort Extreme Model A1354 Back Pad Replacement: Schritt 2, Bild 1 von 1
    • Place double sided tape along the sides of the bottom of the device as shown, this will allow for the rubber cover to stick back on but still be accessible in the future
    • Repeat steps for all four sides
  3. Apple AirPort Extreme Model A1354 Back Pad Replacement: Schritt 3, Bild 1 von 1
    • Line up rubber cover along the bottom of the device.
    • Press down firmly to secure the rubber cover onto place.
Abschluss
To disassemble your device look at device disassembly on the main page.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Ly
201 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 5-2, Forte Spring 2012 Mitglied von Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 13
Insgesamt: 3,033
