Einleitung
If all other troubleshooting options fail, you may need to replace the logic board.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
First start by peeling off the outer rubbery covering on the bottom of the device.
After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
It should make a click when it comes apart.
Take the device out of the casing and orient it so that you can see the WiFi card.
Wires come from the three antennas and connect on the outer edge of the WiFi card.
Carefully pull up on the end of one of the wires to disconnect it from the motherboard.
Do this for the remaining two wires.
There are two clips attached to the upper and lower ends of the WiFi card
Grab the end of one of the clips and pull away from the WiFi card. This should make the clip visibly detached from the WiFi card.
Do the same for the other clip.
Grasp the upper and lower ends of the WiFi card.
Carefully pull the WiFi card to the right.
Completely remove the WiFi card.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
This is the "naked" logic board. You can order a new one and replace it by following the above steps in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
