Zum Hauptinhalt wechseln
Apple AirPort Extreme Model A1354 Outer Case Replacement
Was du brauchst
  1. Apple AirPort Extreme Model A1354 Outer Case Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • First start by peeling off the outer rubbery covering on the bottom of the device.
    • CAUTION: This part is very fragile, so it is recommended that a blow dryer is used on the covering to heat it up. Simply blow dry the covering while slowly peeling it away, and the covering will not tear.
  2. Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 2, Bild 1 von 1
    • After removing the rubber covering, unscrew the five 4.9mm Phillips screws in the holes of the plastic casing.
  3. Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 3, Bild 1 von 1
    • After unscrewing all five screws, remove the plastic casing. The back should now look like the picture shown.
  4. Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 4, Bild 1 von 3 Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 4, Bild 2 von 3 Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 4, Bild 3 von 3
    • The inner metal casing is latched inside the outer white plastic shell, so insert a pry tool underneath the metal casing and pry it apart from the shell.
    • It should make a click when it comes apart.
  5. Apple AirPort Extreme Model A1354 Outer Case Replacement: Schritt 5, Bild 1 von 1
    • Remove the outer casing.
    • The exposed logic board should look like this.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brandon
384 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 5-2, Forte Spring 2012 Mitglied von Cal Poly, Team 5-2, Forte Spring 2012
CPSU-FORTE-S12S5G2
5 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
This guide also applies to model A1408.
Jonas Nilsson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 15
Insgesamt: 4,145
