Zum Hauptinhalt wechseln
Einleitung
This guide shows the reader how to disassemble the Apple Cinema Display M8149 so that the screen can be replaced. The tools required for this section are the spudger and the PH 2 screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury. Flip the Cinema Display so it is on its face and the feet are pointed away from you. Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
    • Before starting, make sure the display is UNPLUGGED. Failure to do so can result in shock and serious injury.
    • Flip the Cinema Display so it is on its face and the feet are pointed away from you.
    • Using the PH 2 screw driver, unscrew the three feet screws (9.52 x 4.43mm).
    • Remove the back foot from the hinge mount by grabbing the foot and pulling upwards.
  2. Locate and remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver. Lift the back plate off of the display. Completely remove the back plate and set it aside.
    • Locate and remove the back plate screws (5.25 x 4.43 mm) using the PH 2 screw driver.
    • Lift the back plate off of the display.
    • Completely remove the back plate and set it aside.
  3. With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover. Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
    • With the PH 2 screw driver, remove the four rim screws (9.52 x 3.43 mm) located on the outer rim of the metal cover.
    • Next, unscrew the four cover screws (11.91 x 2.89 mm) using the PH 2 screwdriver.
  4. Unplug the large plug that connects the control board to the rest of the display. Unplug the blue and gray plug  on the right side of the control board. Unplug the blue and gray plug  on the left side of the control board.
    • Unplug the large plug that connects the control board to the rest of the display.
    • Unplug the blue and gray plug on the right side of the control board.
    • Unplug the blue and gray plug on the left side of the control board.
  5. iPhone Akku Fix Kits
    Nur $29.99
    Buy Now
    Nur $29.99
    Buy Now
  6. Lift the large metal cover which spans across the whole display. Lift the large metal cover which spans across the whole display.
    • Lift the large metal cover which spans across the whole display.
  7. Locate and carefully remove the two tape plugs on either side of the control board using the spudger. Locate and carefully remove the two tape plugs on either side of the control board using the spudger. Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
    • Locate and carefully remove the two tape plugs on either side of the control board using the spudger.
  8. Pull the previously removed tapes out from the metal box with your hand. Peel back the white plastic cover located on the tape plug. Unplug the tape plug on the right of the unit using the spudger.
    • Pull the previously removed tapes out from the metal box with your hand.
    • Peel back the white plastic cover located on the tape plug.
    • Unplug the tape plug on the right of the unit using the spudger.
  9. Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver. Lift away the metal cover to reveal a circuit board with you hand. Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
    • Unscrew the four screws (4.79x2.33mm) on the metal box using the PH 2 screwdriver.
    • Lift away the metal cover to reveal a circuit board with you hand.
    • Unscrew the two terminal screws (4.79x2.34mm) using the PH 2 screwdriver.
  10. Remove the terminal cover. Remove the circuit board from the right side of the unit by gently lifting it out.
    • Remove the terminal cover.
    • Remove the circuit board from the right side of the unit by gently lifting it out.
  11. Turn your attention to the left side of the cinema display. Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board. Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Turn your attention to the left side of the cinema display.
    • Using your fingers, unplug the small white plugs with pink wires from the top and bottom of the circuit board.
    • Using the PH 2 screw driver, remove the four screws (6.9 x 2.55 mm) holding down the circuit board.
    • Remove the circuit board by gently lifting it from the display.
  12. Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting. Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting. Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
    • Lift the screen from the surrounding front cover by sliding your fingers between the two pieces and lifting.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Curtis Musashi
137 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-41, Forte Spring 2011 Mitglied von Cal Poly, Team 10-41, Forte Spring 2011
CPSU-FORTE-S11S10G41
5 Mitglieder
6 Anleitungen geschrieben
hello! where can i buy lcd screen for m8149?
jgill1971 - Antwort
Does anyone know where to get an inexpensive LCD replacement. Mine went primarily magneta except for the outer edges after zapping the pram?! Totally bummed as I bought a DVI to ADC power source and now the monitor is useless in it’s current state. C’est la vie!
quelsac - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 6,480
