Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will help you remove and replace your computers speaker, if speaker is not working properly or at all.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the six 19 mm long screws with a #2 Phillips head screwdriver. Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Release the catch by pushing it in using a plastic opening tool. The catch is off-center, but in line with the middle of the speaker underneath.
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove. Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Lift the handle straight up to remove. Lift the handle straight up to remove.
    • Lift the handle straight up to remove.
  5. Tilt the keyboard up while detaching the ribbon connection by pulling it straight up.  You may have to wiggle the connector sideways to loosen it. Be careful not to force the ribbon while pulling it out to avoid tearing.  Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
  6. Unplug the speaker from the mother board by pulling horizontally.
    • Unplug the speaker from the mother board by pulling horizontally.
  7. Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • Heat the glue to loosen it, then wiggle the speaker up and out. Use the screwdriver to scrape off the remaining glue.
    • An easy way to heat the glue is by using a hair dryer on a low setting.
    • When heating the glue, do not use any high wattage device! This may burn or damage the chips or circuit board.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Josiah
571 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 21-23, Maness Fall 2011 Mitglied von Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Mitglieder
13 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 1,146
