Was du brauchst
Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
Twist thumbscrews on the back to release the panel. Pull panel up to remove.
Release the thumbscrew on the power supply. Pull out the power supply.
Unscrew two philips screws on the ceiling of where the card cage was.
I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
