Zum Hauptinhalt wechseln
Apple Lisa MacWorks II PFG Instalation
Was du brauchst
  1. Apple Lisa MacWorks II PFG Instalation, Disassembly: Schritt 1, Bild 1 von 2 Apple Lisa MacWorks II PFG Instalation, Disassembly: Schritt 1, Bild 2 von 2
  2. Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: Schritt 2, Bild 1 von 2 Apple Lisa MacWorks II PFG Instalation, Remove I/O Board: Schritt 2, Bild 2 von 2
    • Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
    • Release both clips holding the I/O Board.
    • Pull the I/O Board up to remove it.
  3. Apple Lisa MacWorks II PFG Instalation, Removing the 8530 Chip: Schritt 3, Bild 1 von 1
    • Remove the chip marked 8530 at location 9D.
  4. Apple Lisa MacWorks II PFG Instalation, Crystal Insulation: Schritt 4, Bild 1 von 1
    • Next to the chip removed in step 3 is a crystal. These are not always installed with a plastic coating. The crystal shown in the image is insulated.
    • If your crystal is not insulated then tape a small piece of cardboard on top of it.
  5. Apple Lisa MacWorks II PFG Instalation, Installing the Daughter Board: Schritt 5, Bild 1 von 1
    • Ensure the pins on the MW+II PFG (Programable Frequency Generator) are perfectly straight. If they are not then slightly bend them into place.
    • Insert the PFG into the 8530 socket.
  6. Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: Schritt 6, Bild 1 von 3 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: Schritt 6, Bild 2 von 3 Apple Lisa MacWorks II PFG Instalation, Attaching Red and Black Wires: Schritt 6, Bild 3 von 3
    • Locate the chip marked LS132 located at 6A.
    • Connect the Red and Black wires as shown in the second image on this step.
    • It is best to place a piece of electrical tape on the wires to help hold them in place.
  7. Apple Lisa MacWorks II PFG Instalation: Schritt 7, Bild 1 von 1
    • Replace the I/O Board back into Lisa's Card Cage.
    • Replace Lisa's Card Cage Back into the Lisa.
    • Replace the rear panel on the Lisa.
    • MacWorks + II (MW+II) floppy images can be found here.
    • The MW+II manual can be found here which includes detailed instructions how to instal thel MW+II software.
Abschluss
  • MW+II supports Macintosh System Software up to Macintosh System 7.5.5.
  • Supports over 10MB of RAM (more than 4MB requires an XLerator.)
Eine weitere Person hat diese Anleitung absolviert.
Angehängte Dokumente
LisaGuide
1.833 Reputation
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 612
