Was du brauchst
Follow the Apple Lisa Disassembly Guide to remove the Lisa's real panel.
Remove the Lisa's Card Cage.
Remove the Lisa's I/O Board. The I/O Board's clips are marked in red.
Release both clips holding the I/O Board.
Pull the I/O Board up to remove it.
Next to the chip removed in step 3 is a crystal. These are not always installed with a plastic coating. The crystal shown in the image is insulated.
If your crystal is not insulated then tape a small piece of cardboard on top of it.
Ensure the pins on the MW+II PFG (Programable Frequency Generator) are perfectly straight. If they are not then slightly bend them into place.
Insert the PFG into the 8530 socket.
Locate the chip marked LS132 located at 6A.
Connect the Red and Black wires as shown in the second image on this step.
It is best to place a piece of electrical tape on the wires to help hold them in place.
- MW+II supports Macintosh System Software up to Macintosh System 7.5.5.
- Supports over 10MB of RAM (more than 4MB requires an XLerator.)
Eine weitere Person hat diese Anleitung absolviert.
