Was du brauchst
Follow the Apple Lisa Disassembly Guide to remove the Lisa's real panel.
Remove the Lisa's Card Cage.
Remove the CPU Board. It is marked in blue.
Lift up on the CPU Board's clips.
Lift up the CPU Board to remove.
Locate the CPU at location 13A/B/C (the big one.)
Remove the CPU. I used a flat head screwdriver to gently pry up the chip although there are better tools such as a Chip Remover.
Insert the XLerator in the CPU's socket.
Ensure it "click" in all the way.
If the XLerator seems loose then use electrical tape at your discretion to secure it to the CPU Board.
Reinstall the CPU Board into the Lisa's Card Cage.
Reinstall the Lisa's Card Cage into the Lisa.
Reinstall the Lisa's rear panel.
XLerator software can be found on the MacWorks + II (MW+II) Installation floppy.
