Zum Hauptinhalt wechseln
Apple Magic Keyboard 2 A2450 Motherboard Replacement
Was du brauchst
  1. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: Schritt 1, Bild 1 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: Schritt 1, Bild 2 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Lower Case: Schritt 1, Bild 3 von 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: Schritt 2, Bild 1 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: Schritt 2, Bild 2 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement, Motherboard: Schritt 2, Bild 3 von 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 3, Bild 1 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 3, Bild 2 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 4, Bild 1 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 4, Bild 2 von 3 Apple Magic Keyboard 2 A2450 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 3-2, Harley Spring 2024 Mitglied von IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 26
Insgesamt: 73
