Einleitung
This guide will help you replace your Apple Pencil tip.
Was du brauchst
Grab your Apple Pencil Generation 1. Make sure you have replacement tips . You can buy them from Apple or Amazon.
To take off your Apple Pencil's current tip, squeeze it between two fingers and turn it counterclockwise to unscrew it. It should come off within seconds.
Once it's off, place your new Pencil tip on the metal prong and screw it clockwise until it's tight. Once it stops turning easily, you can let go.
