Einleitung
This repair will need:
A T-8 or T-6 Torx Screwdriver.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Turn computer over. Remove battery expansion cover and battery.
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. With monitor hinge at the bottom, remove the two top center screws.
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Remove top left and top right screws.
    • Remove top left and top right screws.
  4. Remove middle left and middle right screws.
    • Remove middle left and middle right screws.
  5. Open computer kickstands.
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. Lift keyboard from bottom and take out of shell.
    • Lift keyboard from bottom and take out of shell.
  8. Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool. Removing both ribbon cables from the motherboard will leave the clamps like so. From here you can access the logic board, hard drive, and floppy drive.
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
  9. Remove the plastic panel on the bottom of the LCD Screen.
    • Remove the plastic panel on the bottom of the LCD Screen.
  10. Open panel on back of the device. Remove 2 T8 torque screws.
    • Open panel on back of the device. Remove 2 T8 torque screws.
  11. Remove the plastic panel underneath the LCD Screen.
    • Remove the plastic panel underneath the LCD Screen.
  12. Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
    • Remove the 2 T8 Torx Screws securing the logic board protection plate from the midsection of the logic board protection plate. Remove the T8 Torx Screw from the back of the plate, underneath the hinge.
  13. Remove the logic board protection plate.
    • Remove the logic board protection plate.
  14. Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
    • Using a plastic spudger, gently pry up the uppermost board fixture. This is the Memory (RAM).
  15. Once the old Memory board is removed, replace it with the new Memory board.
    • Once the old Memory board is removed, replace it with the new Memory board.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Tyler
132 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-66, Walters Spring 2011 Mitglied von Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Mitglieder
3 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,339
