Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you how to replace the keyboard in a simple step by step process.
  1. Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  3. Pull the keyboard ribbon vertically from the logic board to release connection.
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  4. Your computer should look approximately like this.
    • Your computer should look approximately like this.
Abschluss
Byron Hoefer
70 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 4-2, Regan Spring 2011 Mitglied von Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 1,487
