Einleitung
This guide will be teaching you how to easily replace the modem in your computer.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
Pull the keyboard ribbon vertically from the logic board to release connection.
Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
Lift the heat shield up and toward you.
Pull the PRAM battery cable vertically upward to disconnect it.
Remove the battery by pulling up and to the left.
Remove the two T8 Torx screws that attach the heat sink to the processor.
Remove the long silver Phillips #1 screw from the heat sink.
Lift the processor on the right side and pull directly up.
The RAM chips should be in the slots on the processor.
Remove the single black Torx screw from the modem.
Remove the black rectangle that is being held on by the one Torx screw.
Disconnect the cable that is attached to the end of the modem to remove the modem.
