Zum Hauptinhalt wechseln
Apple Powerbook 520 Floppy Drive Replacement
Was du brauchst
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: Schritt 1, Bild 1 von 1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: Schritt 3, Bild 1 von 1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: Schritt 4, Bild 1 von 1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: Schritt 7, Bild 1 von 1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: Schritt 8, Bild 1 von 1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 20-66, Walters Spring 2011 Mitglied von Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 13
Letzte 30 Tage: 22
Insgesamt: 2,727
