Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
In order to obtain access to the internal components you must first follow this step by step general disassembly guide. This will be a first stop in installing a new component that is enclosed by the outer shell.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn computer over. Remove battery expansion cover and battery.
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. With monitor hinge at the bottom, remove the two top center screws.
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Remove top left and top right screws.
    • Remove top left and top right screws.
  4. Remove middle left and middle right screws.
    • Remove middle left and middle right screws.
  5. Open computer kickstands.
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Lift keyboard from bottom and take out of shell.
    • Lift keyboard from bottom and take out of shell.
  7. Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool. Removing both ribbon cables from the motherboard will leave the clamps like so. From here you can access the logic board, hard drive, and floppy drive.
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Abschluss
7 weitere Nutzer haben diese Anleitung absolviert.
Mark McNeff
469 Reputation
2 Anleitungen geschrieben
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Antwort
Thanks been trying to fix this for a long time
Luke - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 4
Letzten 30 Tage: 27
Insgesamt: 4,610
