Zum Hauptinhalt wechseln
Apple Studio Display M2454 CCFL Inverter Replacement
Was du brauchst
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: Schritt 1, Bild 1 von 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: Schritt 1, Bild 2 von 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 2, Bild 1 von 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 3, Bild 1 von 2 Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 3, Bild 2 von 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 5, Bild 1 von 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: Schritt 6, Bild 1 von 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dylan Perry
177 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-27, Maness Winter 2010 Mitglied von Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 6,710
