Zum Hauptinhalt wechseln
Einleitung
Replacing the front buttons on the display.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Apple Studio Display M7649 Front Buttons Replacement, Stand: Schritt 1, Bild 1 von 2 Apple Studio Display M7649 Front Buttons Replacement, Stand: Schritt 1, Bild 2 von 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Front Buttons Replacement, Panels: Schritt 2, Bild 1 von 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Front Buttons Replacement: Schritt 3, Bild 1 von 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Front Buttons Replacement: Schritt 4, Bild 1 von 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Apple Studio Display M7649 Front Buttons Replacement, Metal EMI Shield: Schritt 5, Bild 1 von 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Apple Studio Display M7649 Front Buttons Replacement: Schritt 6, Bild 1 von 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Apple Studio Display M7649 Front Buttons Replacement: Schritt 7, Bild 1 von 2 Apple Studio Display M7649 Front Buttons Replacement: Schritt 7, Bild 2 von 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Apple Studio Display M7649 Front Buttons Replacement, Front Buttons: Schritt 8, Bild 1 von 1
    • Using the spudger, remove the four black panel covers on the edges of the display.
  9. Apple Studio Display M7649 Front Buttons Replacement: Schritt 9, Bild 1 von 1
    • Remove these screws under the panels.
    • There may be more screw holes than actual screws
  10. Apple Studio Display M7649 Front Buttons Replacement: Schritt 10, Bild 1 von 1
    • Remove the two connections that connect the buttons to the logic board
  11. Apple Studio Display M7649 Front Buttons Replacement: Schritt 11, Bild 1 von 1
    • Remove the outer frame and and pull the cables through the hole. Flip the frame upside down.
  12. Apple Studio Display M7649 Front Buttons Replacement: Schritt 12, Bild 1 von 1
    • The red highlighted box is the power button
    • The teal highlighted box is the brightness button
    • This guide will focus on the power button. Removal of the brightness button will follow the same instructions, but you will be working on the left button (teal box) instead of the right (red box)
  13. Apple Studio Display M7649 Front Buttons Replacement: Schritt 13, Bild 1 von 1
    • Remove the screws at the bottom holding the button(s) down
    • In this picture we are removing the power button
  14. Apple Studio Display M7649 Front Buttons Replacement: Schritt 14, Bild 1 von 1
    • Remove and replace the button(s).
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Andrew Tsao
171 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-20, Maness Winter 2010 Mitglied von Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 18
Insgesamt: 2,813
