Zum Hauptinhalt wechseln
Einleitung
Replacing the inverter, a common cause for what looks to be a loss of backlight.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Lay the display facing down with the stand away from you. Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Rotate the display so the legs of the display are now facing you
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Now locate and remove the lone Phillips screw holding the EMI shield to the display
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Now that the screw has been removed, slide the panel towards your body and lift it out. You may need to remove the clear USB port cover to remove the metal EMI shield.
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Remove these three screws holding the board to the display
    • Remove these three screws holding the board to the display
  9. Remove these five cables connection the inverter to the backlights and logic board.
    • Remove these five cables connection the inverter to the backlights and logic board.
    • Taking note where they connect to for reassembly
  10. Remove and replace the inverter
    • Remove and replace the inverter
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Andrew Tsao
165 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-20, Maness Winter 2010 Mitglied von Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 9
Insgesamt: 6,646
