Einleitung
Replacing the panels of the apple display.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Lay the display facing down with the stand away from you.
Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
Rotate the display so the legs of the display are now facing you
Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
2 weitere Nutzer haben diese Anleitung absolviert.
