Einleitung
Replace the fan in your Apple TV 1st Generation.
Was du brauchst
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
Carefully pull the hard drive data cable straight up from its socket on the logic board.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
Lift and remove the fan out of the upper case.
4 weitere Personen haben diese Anleitung absolviert.
