Was du brauchst
Insert a Jimmy into the left side of the Apple TV, then work your way around the bottom and pull the base off.
First, peel off the thermal heat sink.
Then, using a Phillips #0 screwdriver, unscrew the 5 screws holding the heat sink.
1. Unhook the Power Supply Cable.
2. Unhook the IR Sensor cable
Lift the logic board up with a Spudger.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
