Einleitung
In this guide we will disassemble and remove the power supply from an Apple TV 4K
Was du brauchst
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
Four 10 mm screws
Lift and remove the heat sink assembly from the device.
Use plastic spudger to pull up on all three antenna connectors to remove them.
Remove rubber piece from front side of device.
Unscrew the following screws holding the logic board in place using the T7 Torx:
Two black 3 mm screws
Two silver 4 mm screws
Use a spudger to pry up logic board. Try lifting it up from the front side.
Remove logic board and set aside.
Use a T7 Torx to remove the screws:
Five 5mm screws
Carefully flip the device upside down to remove the logic board/power supply mount.
Undo the latch connecting the power connector to the power supply.
Feed the wire though the logic board/power supply mount.
Use a screwdriver with a T-7 Torx bit to remove the following screws:
Five black 3mm screws
lift the power supply out of it's mount.
Use a T6 Torx to remove the two screws holding the power supply connector in place. Pull the power connector away from the case.
Two 3mm screws
9 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Please, explain the 12V power supply topic: does that means it can be installed in a car or a boat out of the box?
