Einleitung
This guide will show you how to properly get into your Apple TV 4K's remote and get access to the logic board for replacement.
Was du brauchst
Heat iOpener according to manufacturer's instructions.
Place over the face of the remote to soften the adhesive under the glass.
Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
Lift the latch holding back the connector to the battery.
Use tweezers to disconnect the battery connector.
Using a plastic spudger, gently remove the logic board from the case of the remote.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
