Zum Hauptinhalt wechseln
Apple Watch Adhesive Replacement
Was du brauchst
  1. Apple Watch Adhesive Replacement, Adhesive: Schritt 1, Bild 1 von 2 Apple Watch Adhesive Replacement, Adhesive: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool to scrape adhesive off the back of the screen.
  2. Apple Watch Adhesive Replacement: Schritt 2, Bild 1 von 2 Apple Watch Adhesive Replacement: Schritt 2, Bild 2 von 2
    • You may be able to peel up the adhesive with tweezers.
    • Once you have all of the pieces of adhesive removed, you may want to use an alcohol soaked q-tip to clean any residue off the back of the screen.
  3. Apple Watch Adhesive Replacement: Schritt 3, Bild 1 von 2 Apple Watch Adhesive Replacement: Schritt 3, Bild 2 von 2
    • Use tweezers to peel the outer ring off of one of the adhesive strip pads.
    • Be sure to get both the double-sided adhesive and the brown backing paper.
    • If you're having trouble navigating the double-sided adhesive, check out this video.
    • Be very careful not to fold, bend, or stretch the adhesive tape, as this will make it too thick to seal the screen without a ridge between the screen and the case.
  4. Apple Watch Adhesive Replacement: Schritt 4, Bild 1 von 3 Apple Watch Adhesive Replacement: Schritt 4, Bild 2 von 3 Apple Watch Adhesive Replacement: Schritt 4, Bild 3 von 3
    • Lay the backed adhesive tape down on the Force Touch sensor, around the edge of the case where the screen rests.
    • Start in a corner with the tape as close to the corner wall as possible.
    • Press on the brown backing paper with a plastic opening tool to secure the adhesive around the entire perimeter.
  5. Apple Watch Adhesive Replacement: Schritt 5, Bild 1 von 2 Apple Watch Adhesive Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to reconnect the display data and digitizer cable connectors.
    • Be careful not to touch any of the contacts directly, as your finger oils may impede connectivity.
  6. Apple Watch Adhesive Replacement: Schritt 6, Bild 1 von 3 Apple Watch Adhesive Replacement: Schritt 6, Bild 2 von 3 Apple Watch Adhesive Replacement: Schritt 6, Bild 3 von 3
    • To reinstall the metal bracket, line up the single tab with the slot in the top of the lower half, and slide the bracket down.
    • Snap the upper bracket in place.
  7. Apple Watch Adhesive Replacement: Schritt 7, Bild 1 von 3 Apple Watch Adhesive Replacement: Schritt 7, Bild 2 von 3 Apple Watch Adhesive Replacement: Schritt 7, Bild 3 von 3
    • Line the battery connector up with its mate on the cable inside the watch body.
    • Use tweezers to press the two connectors together.
  8. Apple Watch Adhesive Replacement: Schritt 8, Bild 1 von 3 Apple Watch Adhesive Replacement: Schritt 8, Bild 2 von 3 Apple Watch Adhesive Replacement: Schritt 8, Bild 3 von 3
    • If your replacement battery came with pre-installed adhesive, peel off the protective tab now, exposing the adhesive.
    • Rotate the battery down into its slot, and press it into position.
    • Press the battery down against the S1 to re-adhere it in place.
    • Now is the best time to test powering on your watch—if it doesn't turn on, double check all three connectors and try again.
  9. Apple Watch Adhesive Replacement: Schritt 9, Bild 1 von 1
    • Use tweezers to peel off the adhesive backing strip.
    • Peel the backing strip up halfway, then snip it with scissors so you can peel the rest off without it snagging on the display.
  10. Apple Watch Adhesive Replacement: Schritt 10, Bild 1 von 3 Apple Watch Adhesive Replacement: Schritt 10, Bild 2 von 3 Apple Watch Adhesive Replacement: Schritt 10, Bild 3 von 3
    • Move the screen back to the right, folding the display data and digitizer cables neatly.
    • Center the screen over the case and press it down firmly onto the adhesive.
    • Alternatively, you can use screen vice clamps around the perimeter of your device to set the new adhesive.
Ziellinie
227 weitere Nutzer:innen haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.817 Anleitungen geschrieben
46 Kommentare
Where can I find the new screen.
Crissel Largo - Antwort
THERE WOULD BE A PROBLEM WITH THE I.C. rewriting aiu moment of the change of LCD.?
wallace@freesurf.ch
vallottonge - Antwort
How long before the adhesive strips will be back in stock? I've been waiting months now and still no update :)
Annie Booth - Antwort
me too when can we expect it?
Luis Deluna -
me too!!!!!!
Anthony Zamora -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 58
Letzte 7 Tage: 390
Letzte 30 Tage: 1,630
Insgesamt: 328,323
