Einleitung
Use this guide to open your Apple Watch SE for repairs.
You’ll need replacement adhesive to reattach the display when reassembling the device.
Was du brauchst
Before starting repairs, take your watch off the charger and power it down.
If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
In diesem Schritt verwendetes Werkzeug:Safety Glasses$3.19
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, closest to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
Insert an opening pick in the gap you've created.
Slide the opening pick along the short edge of the watch to cut the adhesive.
Slide the opening pick around the corner and along the long edge where the crown is located to cut the display adhesive.
Slide the opening pick around the corner to cut the remaining adhesive on the short edge farthest away from the crown.
Place the watch on a flat surface and use an opening pick to slice through any remaining adhesive.
Slide an opening pick under the opposite display edge of the watch crown.
Reinsert the opening pick on the short edge of the watch, next to the watch crown.
Twist the opening pick to loosen the display off the watch case.
Lift the display and carefully pull it in direction of the short edge farthest away from the crown.
Swing the display open to an upward position.
To reassemble your Apple Watch SE, follow these instructions in reverse order.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
Opening didn’t go as planned? Check out our Answers community for troubleshooting help.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Pardon what may be a question with an obvious answer, but how do you re-close the Apple Watch SE (gen1)? Mine has popped open on its own after a few years of abuse and I can't get it to stay closed.
Other than the adhesive, which I will surely need to acquire and reapply, is there a mechanism that clips the screen to the rest of the watch/housing? If there is, I can't see it (or it broke and fell out when the watch opened.
Thanks in advance!
How would I reapply the adhesive? Are there any sensors I have to disconnect from the screen and/or reconnect after the new one is installed?
