Einleitung
This guide will lead you through the steps of replacing an Apple Watch SE band. Replacing the watch band is a simple and affordable way to transform your device. This guide will walk you through the process, step-by-step, so you can effortlessly swap out your old band for a new one, or replace a broken one, and get back to enjoying your watch.
Was du brauchst
Turn off your device by holding down the side button until the slider appears.
Tap the Power button at the top right hand corner.
Slide the Power Off slider to the right.
Lay your Apple Watch face down on a soft, clean surface to avoid scratching the screen.
Hold down one of the release buttons on the back of the device, and slide out its corresponding band at the same time.
Gently wipe any residue off of the back of the watch using a gentle towel, cotton swab, or cotton ball.
Take the new watch band and make sure the side of the band with metal connectors is facing the watch, and the correct orientation is followed.
2 weitere Personen haben diese Anleitung absolviert.
