Einleitung
You need a Metal spudger and a screwdriver
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Insert a metal spudger to open the plastic part under the Keyboard Insert a metal spudger to open the plastic part under the Keyboard
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Remove the screw
    • Remove the screw
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Pull the lock up and disconnect the connection cable Pull the lock up and disconnect the connection cable Pull the lock up and disconnect the connection cable
    • Pull the lock up and disconnect the connection cable
  5. Keeping the connection cable, push out the logic board's placement
    • Keeping the connection cable, push out the logic board's placement
  6. Unlock the latch of the logic board
    • Unlock the latch of the logic board
  7. Remove the logic board from the placement
    • Remove the logic board from the placement
Abschluss
13 weitere Nutzer haben diese Anleitung absolviert.
Nicola
470 Reputation
1 Anleitung geschrieben
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - Antwort
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - Antwort
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - Antwort
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - Antwort
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 10
Letzte 7 Tage: 57
Letzte 30 Tage: 294
Insgesamt: 35,535
