Zum Hauptinhalt wechseln
Apple iPod Dock Connector Cable Replacement
Was du brauchst
  1. Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: Schritt 1, Bild 1 von 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: Schritt 1, Bild 2 von 3 Apple iPod Dock Connector Cable Replacement, iPod Dock Connector Cable: Schritt 1, Bild 3 von 3
    • Unscrew the four Phillips screws on the backside of the docking system.
    • The screws are located quite deep. Make sure you have a long screwdriver to be able to reach the screws.
    • Be aware of the plastic threads. Using too much force can tear this up.
  2. Apple iPod Dock Connector Cable Replacement: Schritt 2, Bild 1 von 1
    • Separate the housing in two parts.
    • The dock connector is slid in two parts on the top of the system, make sure you slide the two housing parts in this line of direction.
    • The two parts are glued on the sides of the speakers. Use some force to separate the two housing parts.
    • The internal parts are still connected to each other. Don't pull the housing parts too far from each other.
  3. Apple iPod Dock Connector Cable Replacement: Schritt 3, Bild 1 von 1
    • Slide the dock connector out of the housing part.
  4. Apple iPod Dock Connector Cable Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the three screws using a Phillips #2 screwdriver to remove the T-shaped circuit board holder.
  5. Apple iPod Dock Connector Cable Replacement: Schritt 5, Bild 1 von 1
    • Remove the T-shaped circuit board holder.
  6. Apple iPod Dock Connector Cable Replacement: Schritt 6, Bild 1 von 1
    • Remove the circuit board from the housing part.
    • The circuit board is still connected to another circuit board with a cable.
  7. Apple iPod Dock Connector Cable Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the 5-pin connector between the two circuit boards.
    • The connectors are tightly connected. Hold the other circuit board to prevent it from breaking while disconnecting the 5-pin connector.
  8. Apple iPod Dock Connector Cable Replacement: Schritt 8, Bild 1 von 2 Apple iPod Dock Connector Cable Replacement: Schritt 8, Bild 2 von 2
    • Look how the cables are oriented.
    • Take a picture with your phone. It's easier to look it up than recalling your memory.
  9. Apple iPod Dock Connector Cable Replacement: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
  10. Apple iPod Dock Connector Cable Replacement: Schritt 10, Bild 1 von 1
    • Heat up the solder.
    • If you don't want to damage your workspace, it's probably handy to place something underneath.
    • The circuit board will be getting hot. To make it more stable you can clamp it in a vise or alligator clips.
    • The heated solder tends to fume—do not inhale this! Do this in a well ventilated room.
  11. Apple iPod Dock Connector Cable Replacement: Schritt 11, Bild 1 von 2 Apple iPod Dock Connector Cable Replacement: Schritt 11, Bild 2 von 2
    • If the solder becomes fluid, keep the desoldering pump near the solder.
    • Push the button on the desoldering pump to suck the solder.
    • Solder will solidify fast, so you need to act quickly.
  12. Apple iPod Dock Connector Cable Replacement: Schritt 12, Bild 1 von 1
    • Strip the cables with a wire stripper.
  13. Apple iPod Dock Connector Cable Replacement: Schritt 13, Bild 1 von 2 Apple iPod Dock Connector Cable Replacement: Schritt 13, Bild 2 von 2
    • Check if the cable is in the right position.
    • Heat up the contact point on the circuitboard.
    • If the contact point is hot enough, you can add a little bit of solder.
    • Don't inhale the fumes.
Abschluss
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
Anoniem
19 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 451
