Zum Hauptinhalt wechseln
Einleitung
This guide details how to replace the front grille of the Apple iPod Hi-Fi speaker system.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Apple iPod Hi-Fi Grille Replacement, Grille: Schritt 1, Bild 1 von 1
    • Warm up the glue by using the hair dryer on the grille for 5-10 minutes.
    • You can skip this step if you don't have access to a hair dryer. However, if you skip this step, the next step will take longer and will be harder.
  2. Apple iPod Hi-Fi Grille Replacement: Schritt 2, Bild 1 von 1
    • Take one spudger and fit it under the grille.
    • Use your first spudger to pry up and make room to insert a second one.
    • Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
    • Use the other spudger to raise the grille, allowing you to see where you're working.
    • Since you're cutting the glue, the grille may not stick as well when reassembled.
  3. Apple iPod Hi-Fi Grille Replacement: Schritt 3, Bild 1 von 1
    • Pull the grille off the Apple iPod Hi-Fi with your hands.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Cal Poly, Team S16-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S16-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S16G1
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 7
Letzten 30 Tage: 17
Insgesamt: 1,010
