Zum Hauptinhalt wechseln
Einleitung
This is a replacement guide for the external body of the Apple iSight webcam. The external body of the Apple iSight is composed of the silver structure and the cap with the Apple logo. The overall process is quick and easy. Follow these steps for a successful replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Press the Apple logo through to pull apart the body frame from the body of the webcam. Press the Apple logo through to pull apart the body frame from the body of the webcam.
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
IUPUI, Team S5-G1, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
3 Mitglieder
3 Anleitungen geschrieben
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 505
