Einleitung
This is a replacement guide for the external body of the Apple iSight webcam. The external body of the Apple iSight is composed of the silver structure and the cap with the Apple logo. The overall process is quick and easy. Follow these steps for a successful replacement.
Was du brauchst
Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
Press the Apple logo through to pull apart the body frame from the body of the webcam.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
