Einleitung
Using this guide will help you replace the batteries in your Archos 101 G9 tablet.
Most mobile devices (including tablets) use built-in batteries to keep their electronic devices running. Make sure the device is turned off and not plugged in to any external power source prior to beginning this guide. Be careful when opening up the device; the display is attached to the rest of the tablet with a ribbon cable. Don’t bend the batteries excessively while completing the last step. Bending the batteries can possibly lead to overheating and may cause a fire. Never use metal prying tools to remove a battery.
Was du brauchst
Place an iFixit opening tool in the crease where the display assembly and back of the device meet.
Slide the tool firmly through the crease on one side of the device, twisting as you go to create separation.
When you reach the corner, carefully pry the two halves of the device apart.
Repeat for the remaining three sides and corners.
Desolder the BATT+ connection from the motherboard.
Desolder the BATT- connection from the motherboard.
Desolder the NTC+ connection from the motherboard.
Desolder the NTC- connection from the motherboard.
