Zum Hauptinhalt wechseln
Archos 5 Screen Replacement
Was du brauchst
  1. Archos 5 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Please be sure that your device is powered off before attempting any repairs.
    • Please be aware that any further steps could possibly void the warranty of your Archos 5.
  2. Archos 5 Screen Replacement: Schritt 2, Bild 1 von 2 Archos 5 Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool to take off 3 black sticky pads that cover the screws.
    • Use the screwdriver(PH000) to remove the screws located under the pads.
    • Lift the stand in order to get to the fourth screw.
  3. Archos 5 Screen Replacement: Schritt 3, Bild 1 von 2 Archos 5 Screen Replacement: Schritt 3, Bild 2 von 2
    • Carefully pry open all 4 sides of the Archos 5 using the plastic opening tool.
    • Once all sides of the device are pried open, gently open the device .
    • Be careful not to tear the foil which connects the LCD screen to the motherboard!
  4. Archos 5 Screen Replacement: Schritt 4, Bild 1 von 2 Archos 5 Screen Replacement: Schritt 4, Bild 2 von 2
    • Once you have opened your device, fold the screen away from the battery.
    • Unplug the touch pad from the motherboard. Do this by applying pressure on the thin black piece(attached at the bottom of the metallic foil) Press the plastic spudger against the thin black piece and release it.
    • Use a plastic spudger instead of a metal spudger!
  5. Archos 5 Screen Replacement: Schritt 5, Bild 1 von 2 Archos 5 Screen Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, lift the touch pad away from the cracked screen
    • Be careful not to pull or tear the small film/wires as shown in the picture. These are vital to connecting the glass screen and the LCD screen.
  6. Archos 5 Screen Replacement: Schritt 6, Bild 1 von 2 Archos 5 Screen Replacement: Schritt 6, Bild 2 von 2
    • Lift the cracked screen off of your Archos 5 using the regular plastic spudger.
    • Be careful not to rip or tear the film connecting the glass screen and the LCD screen.
  7. Archos 5 Screen Replacement: Schritt 7, Bild 1 von 1
    • Peel the plastic screen away from your shattered glass screen, and replace with your new glass screen.
    • The film connecting the glass screen and the LCD screen is attached the plastic and will peel away with it. Be careful not to rip or tear it.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ally Hummel
378 Reputation
3 Anleitungen geschrieben
University of Alabama, Team 1-5, Sydow campbell Fall 2015 Mitglied von University of Alabama, Team 1-5, Sydow campbell Fall 2015
UA-SYDOW CAMPBELL-F15S1G5
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 2,017
