Einleitung
This guide will teach you how to remove and replace the camera on the Archos 70b device. It will guide you through opening the device, removing the camera from the motherboard, and then do the steps backwards to replace it.
Was du brauchst
Remove the plastic cover from the camera.
Removal of the plastic cover makes disassembly easier.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
