Zum Hauptinhalt wechseln
Einleitung
This guide will show you how to replace the front button panel.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the plastic cover over the batteries on both sides of the device.
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Using the Philips Screwdriver, remove the top 2 screws.
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Remove the face. Remove the face.
    • Remove the face.
Abschluss
Bryant Bucci
97 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Freund Spring 2018 Mitglied von IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Mitglieder
2 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 82
