Einleitung
This guide will show you how to replace the motherboard
  1. Remove the plastic cover over the batteries on both sides of the device.
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
    • Remove the face.
    • Remove four surrounding T5 screws as shown
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Abschluss
Shaun Rifield
Mitglied seit 21.03.2018
121 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Freund Spring 2018 Mitglied von IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Mitglieder
2 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 44
