Zum Hauptinhalt wechseln
Arlo Pro 2 Camera Motherboard Replacement
Was du brauchst
  1. Arlo Pro 2 Camera Motherboard Replacement, Camera Motherboard: Schritt 1, Bild 1 von 3 Arlo Pro 2 Camera Motherboard Replacement, Camera Motherboard: Schritt 1, Bild 2 von 3 Arlo Pro 2 Camera Motherboard Replacement, Camera Motherboard: Schritt 1, Bild 3 von 3
    • Press the release button on the camera and gently pull apart the casing to open the device.
    • Remove the battery from inside the case.
  2. Arlo Pro 2 Camera Motherboard Replacement: Schritt 2, Bild 1 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 2, Bild 2 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Use a T5 Torx screwdriver to remove the four 7 mm screws securing the camera case.
    • Carefully pull the outside of the case apart from the internal case to remove the camera components from the outside casing.
  3. Arlo Pro 2 Camera Motherboard Replacement: Schritt 3, Bild 1 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 3, Bild 2 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove four 4 mm screws connecting the daughterboards to the motherboard.
    • Seperate the daughterboards from the motherboard and camera casing.
  4. Arlo Pro 2 Camera Motherboard Replacement: Schritt 4, Bild 1 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 4, Bild 2 von 3 Arlo Pro 2 Camera Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Use a Flathead 4 mm screwdriver to remove the four 7 mm screw posts connecting the motherboard to the case.
    • Carefully pull the motherboard apart from the camera casing.
  5. Arlo Pro 2 Camera Motherboard Replacement: Schritt 5, Bild 1 von 2 Arlo Pro 2 Camera Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the white cord from the port on the motherboard, by gently pulling away from the port to fully isolate the motherboard from the case.
Abschluss
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Ben I.
493 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 2-2, Botvin Spring 2025 Mitglied von UMass Dartmouth, Team 2-2, Botvin Spring 2025
UMASSD-BOTVIN-S25S2G2
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 21
Insgesamt: 175
