Einleitung
If you have ever had to go to an eyeglasses store, you already know how expensive they can be. This guide aims to be a cheaper alternative to replacing the lens in your Armani Exchange AX1017 glasses frame. It is safe, quick, and easy for anyone with glasses to do.
Was du brauchst
Remove the screw between the lens and the frame using the glasses repair kit's Phillips-head screwdriver.
Once removed, take a damp cloth (a cloth soaked in rubbing alcohol is preferred for the best clean) and clean inside of frame.
Take your new lens and place it carefully into the frame. Make sure that the lens is slotted correctly into the frame, aligning the edges on the lens and the frame.
Screw the frame back together using the Phillips head screwdriver, ensuring that the new lens is slotted correctly into the frame.
The guide gives complete instructions on removing, replacing, and returning the glasses back to their original state.
Eine weitere Person hat diese Anleitung absolviert.
