Einleitung
The device will be disassembled down to the motor, the power cords will be disconnected, and the motor removed of your ArmorAll AA255.
Was du brauchst
Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
Pull the ball cage to remove it from the main housing.
Remove one 13mm nut from the main housing.
Remove metal ring from the main housing.
Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
Turn the whole body over to separate motor cover.
Use a PH2 screwdriver to remove the five 15mm screw.
Remove the white power wire from the motor cover.
Pull the motor cover from the main housing.
Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
6 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Medida de los carboncitos que lleva el motor?
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
