Einleitung
Unplug the vacuum before repair. The cord is easily disconnected and replaced once the vacuum is disassembled adequately.
Was du brauchst
Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
