Einleitung
Make sure the cord is unplugged.
Was du brauchst
Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
Pull the black handle.
Using a PH2 screwdriver, unscrew the single 12mm screw shown.
Using the spudger, take out the switch. Do this by pushing the spudger against the switch on both sides as shown and then pull the switch out.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Any idea where to find a replacement switch? I did not see one on Amazon or eBay.
