Zum Hauptinhalt wechseln
Arnova 7K G3 Camera Replacement
Was du brauchst
  1. Arnova 7K G3 Camera Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Arnova 7K G3 Camera Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Arnova 7K G3 Camera Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • Remove four 5 mm Phillips #00 screws from each corner of the tablet.
  2. Arnova 7K G3 Camera Replacement: Schritt 2, Bild 1 von 2 Arnova 7K G3 Camera Replacement: Schritt 2, Bild 2 von 2
    • Place the iFixit opening tool in the notches between the cases and pull the covers apart.
  3. Arnova 7K G3 Camera Replacement: Schritt 3, Bild 1 von 1
    • Repeat step two until 3/4 of the rear cover is unlatched.
    • Proceed to remove the rear cover by gently pulling it apart by hand.
  4. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 4, Bild 1 von 2 Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Logic Board Ribbon Connectors: Schritt 4, Bild 2 von 2
    • Peel the copper tape covering the ribbon connector with a set of tweezers.
  5. Arnova 7K G3 Camera Replacement: Schritt 5, Bild 1 von 3 Arnova 7K G3 Camera Replacement: Schritt 5, Bild 2 von 3 Arnova 7K G3 Camera Replacement: Schritt 5, Bild 3 von 3
    • Locate the two gray pins on the ribbon connector.
    • Grab the first pin with tweezers and gently pull it towards the ribbon. Repeat the step.
    • Gently pull the ribbon cable out of the connection port.
  6. Arnova 7K G3 Camera Replacement: Schritt 6, Bild 1 von 3 Arnova 7K G3 Camera Replacement: Schritt 6, Bild 2 von 3 Arnova 7K G3 Camera Replacement: Schritt 6, Bild 3 von 3
    • Locate the ribbon connector two.
    • Locate the pins of ribbon connector two. Repeat step two for unlocking the pins.
    • Gently pull the ribbon out of the connection port.
  7. Arnova 7K G3 Camera Replacement, Disassembling Arnova 7K G3 Motherboard: Schritt 7, Bild 1 von 1
    • Remove the two Phillips #00 screws from the motherboard.
  8. Arnova 7K G3 Camera Replacement: Schritt 8, Bild 1 von 1
    • Gently lift up the motherboard and reorient it in a more efficient manner in order to locate the desired components.
  9. Arnova 7K G3 Camera Replacement, Camera: Schritt 9, Bild 1 von 2 Arnova 7K G3 Camera Replacement, Camera: Schritt 9, Bild 2 von 2
    • Locate the camera and camera ribbon connection on the backside of the motherboard.
  10. Arnova 7K G3 Camera Replacement: Schritt 10, Bild 1 von 2 Arnova 7K G3 Camera Replacement: Schritt 10, Bild 2 von 2
    • Unlock the camera ribbon connector clip using a pair of tweezers.
  11. Arnova 7K G3 Camera Replacement: Schritt 11, Bild 1 von 3 Arnova 7K G3 Camera Replacement: Schritt 11, Bild 2 von 3 Arnova 7K G3 Camera Replacement: Schritt 11, Bild 3 von 3
    • Gently by hand, remove the camera and its ribbon by pulling the camera away from the motherboard.
    • There is adhesive foam on the backside of the camera that may cause some difficulty when removing the camera.
Abschluss
Kue
301 Reputation
3 Anleitungen geschrieben
Michigan Tech, Team 1-2, Lauer Spring 2015 Mitglied von Michigan Tech, Team 1-2, Lauer Spring 2015
MTU-LAUER-S15S1G2
2 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 223
