Einleitung
Before replacing any components on the Arnova 7K G3 tablet, disassembly is required. That process starts with removing the rear cover to gain access to a majority of the components including the battery, speaker, and logic board.
Was du brauchst
Remove four 5 mm Phillips #00 screws from each corner of the tablet.
Place the iFixit opening tool in the notches between the cases and pull the covers apart.
Repeat step two until 3/4 of the rear cover is unlatched.
Proceed to remove the rear cover by gently pulling it apart by hand.
