Einleitung
This is the first step taken in order to fix many of the parts in the Aroma ARC-914SBD rice cooker. Be careful to not strip any of the screws.
Was du brauchst
The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
Once the condensation catcher has been removed, set it aside for reassembly later.
Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
Where can you buy a replacement lid?
Where can I buy the replacement?
