Einleitung
The expansion pipe allows the angle of the parabolic dish to be adjusted in order to achieve maximum light focus on the cooker flat. The T-bar also supports the weight of the entire parabolic solar panels.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Insert a 14mm bolt through each tripod leg and through the center plate. Secure each bolt by hand threading a nut on the other side.
Tighten each nut using two 14mm wrenches until each leg is stable and the tripod will stand on its own.
Center the bottom of the expansion pipe between the tabs of the t-bar bracket. Insert a 14mm bolt through the bracket and expansion pipe and hand thread a nut. Use 14mm wrenches to secure the assembly.
To disassemble your device, follow these instructions in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
