Einleitung
If you getting a new antenna doesn't work, there might be a problem with the antenna connection inside the camera. This guide will show you how to replace input cable that attaches the antenna to the motherboard.
Was du brauchst
Gently pull back the motherboard to expose many of the component's wired connections.
Take out the screw holding the antenna wire with the PH1 size Phillips head bit.
Screw length: 5.3mm
Gently pry open the circuit board attached to the antenna wire using a metal spudger.
Eine weitere Person hat diese Anleitung absolviert.
